VB error
benf
VB error
Post by benf »
I had this problem before and it went away and now its back.
We are LT12p6 . we had some issues with plugins after the update so i had to disable almost all addons. I put them back in once we fixed the issue , but once I put the announce maintenance back i keep getting an error in the vb script on every desktop and server.
I look and the file is there it just says x=msgbox and then the message we have on there.
Should I script maybe deleting and re-copying the vb file??
Re: VB error
yes, also look at the text in the message for a quote or something that would cause the VB script which is just a messagebox show command to fail to open message box. Typically it's something in the actual message.
benf
Re: VB error
Post by benf »
Thanks thats what it was, I was trying to get a structured message and I had two enters for a seperate line and thats what caused it.
Return to “Announce Maintenance Plugin”
