Connectivity problems (1.0.16)
This forum is for supporting the PFSense plugin and any internal scripts and services.
tuxarn
Post by tuxarn »
I have some problems recieving information from the PFSense firewall to PFSense 4 Labtech, i have tripplechecked the reqiured information such as: Tittle, User Name, URL, Password. Tried several Firewall useraccounts and checked the labtech networkdevice tab for older cached devices with the same IP-adress.
When i'm bringing up PFSense 4 Labtech (doesn't matter if it's in the location tab or directly under View>Labtech 4 PFSense) it shows no information at all, neither am i able to manage the firewall through the tunnel. I'm however able to use the "tunnel" if i VPN onto the same network as the firewall are located on, but that is ofcourse a tunnel in itself, and there wouldnt really be a purpouse of this function if i was forced to go that route everytime i suppose.
Anyone familiar with this issue?
Re: Connectivity problems (1.0.16)
There should be an agent on that network probing the firewall for data. It would be scripted so we will see script logs. Need to see what is being reported back.
tuxarn
Post by tuxarn »
Cubert wrote: Thu Mar 22, 2018 1:54 pm There should be an agent on that network probing the firewall for data. It would be scripted so we will see script logs. Need to see what is being reported back.
"We may have failed to install WGET -> Installing the following packages:
wget
By installing you accept licenses for the packages.
Wget v1.19.4 (forced)
Get-OSArchitectureWidth : The term 'Get-OSArchitectureWidth' is not recognized
as the name of a cmdlet, function, script file, or operable program. Check the
spelling of the name, or if a path was included, verify that the path is correc
t and try again.
At C:\ProgramData\chocolatey\lib\Wget\tools\chocolateyinstall.ps1:5 char:17
+ $zipFile = if ((Get-OSArchitectureWidth 64) -and $env:chocolateyForceX86 -ne
'tr ...
+ CategoryInfo : ObjectNotFound: (Get-OSArchitectureWidth:String)
[], ParentContainsErrorRecordException
+ FullyQualifiedErrorId : CommandNotFoundException
The install of wget was NOT successful.
Error while running 'C:\ProgramData\chocolatey\lib\Wget\tools\chocolateyinstall.ps1'.
See log for details.
Chocolatey installed 0/1 package(s). 1 package(s) failed.
Failures:
- wget"
I found this error.
tuxarn
Post by tuxarn »
Also got this now:
"The Script(6065) was successful in the Then section.
Script: S6065 - Starting at Server Time: Thursday, March 22, 2018 3:36:01 PM
IF F5 ValueOne (P1): MYCMD Comparer (P2): 8 ValueTwo (P3): GETSTATS T: 0.4010535
L1 F20 SetType(P1):1 Parameter(P2):True VariableName(P3):ScriptEngineEnableLogger T: 0.4020549
L3 F154 Folder (P1): %windir%\ltsvc\PFSense T: 0.4020549
L4 F90 File (P1): %windir%\ltsvc\PFSense\pfsense.ps1 T: 4.5986453
L5 F90 File (P1): %windir%\ltsvc\PFSense\pfsense.bat T: 12.7257939
L6 F109 Delimiter (P2): Variable (P3): WGETPROBE T: 30.8753304
L7 F70 Value (P1): WGETPROBE Comparer (P2): 8 To (P3): GNU Wget Jump (P4): :RUNPROBE T: 39.0094757
L8 F109 Delimiter (P2): Variable (P3): CFINSTALLED T: 39.0094757
L9 F70 Value (P1): CFINSTALLED Comparer (P2): 8 To (P3): Settings Jump (P4): :INSTALLWGET T: 53.2194738
L14 F139 Note (P1): :INSTALLWGET T: 53.2194738
L15 F109 Delimiter (P2): Variable (P3): WGETRESULT T: 53.2194738
L16 F70 Value (P1): WGETRESULT Comparer (P2): 8 To (P3): installed 1/1 package Jump (P4): :RUNPROBE T: 67.3844549
L17 F29 Message (P1): 'We may have failed to install WGET -> Installing the following packages:
wget
By install...' T: 67.3844549
L18 F129 Jump (P1): T: 67.3874534"
We use WGet and install, if it fails to install the script will not collect data as probe is not functional. Need to determine why script can not do installs
tuxarn
Post by tuxarn »
We updated Chocolatey and then the installation of Wget worked and then everything was fine.
Return to “PFSense 4 LabTech”
