After an upgrade of CCleaner plugin to build 1.0.4.x can't open license manager
Posted: Wed Feb 14, 2018 2:08 pm
Depending on where your upgrading from you might run into this issue at some point when upgrading from a older build (1.02.x or 1.03.x).
Drop all the tables in SQL by executing the following in SQLYog
DROP TABLE plugin_sw_ccleaner_config;
DROP TABLE plugin_sw_ccleaner_analyze;
DROP TABLE plugin_sw_ccleaner_analyze_detail;
DROP TABLE plugin_sw_ccleaner_clean;
DROP TABLE plugin_sw_ccleaner_clean_detail;
DROP TABLE plugin_sw_ccleaner_enable;
DROP TABLE plugin_sw_ccleaner_configs;
DROP TABLE plugin_sw_ccleaner_exclude;
Then restart the DBagent to recreate the tables. Re-enable the clients and apply licenses.
