After an upgrade of CCleaner plugin to build 1.0.4.x can't open license manager
Depending on where your upgrading from you might run into this issue at some point when upgrading from a older build (1.02.x or 1.03.x).
Drop all the tables in SQL by executing the following in SQLYog
DROP TABLE plugin_sw_ccleaner_config;
DROP TABLE plugin_sw_ccleaner_analyze;
DROP TABLE plugin_sw_ccleaner_analyze_detail;
DROP TABLE plugin_sw_ccleaner_clean;
DROP TABLE plugin_sw_ccleaner_clean_detail;
DROP TABLE plugin_sw_ccleaner_enable;
DROP TABLE plugin_sw_ccleaner_configs;
DROP TABLE plugin_sw_ccleaner_exclude;
Then restart the DBagent to recreate the tables. Re-enable the clients and apply licenses.
