LT version: 11
Admon version: 1.0.0.88
I have enabled "Monitor any additions to Admin groups". However, Alarms are not being generated when a user is added to Local Administrators group. I DO see the new user listed for the computers I'm testing, but there are no Alerts or Tickets and the indicator in left most column remains Green. Also, I'm running Admon hourly and waiting until the top of the hour when I see the Admon script complete before I check the Alarm in Admon. Please advise.
No alerts on Additions
Re: No alerts on Additions
Let me look in to this process and I will get back to you.
Can you post the logs from LTHost located at "C:\Windows\LTSvc\Admon\Admon_Log_(date).txt" During a failure test?
Sorry, I didnt get an email notification that you responded to me. I just checked this forum again over the weekend and saw you responded. I tested again yesterday just prior to 4pm so the 4pm check that Admon did should have alerted me that administrators were added to agent names 'JEREMY-PC1' and 'VENOM'. Log file attached.
- Admon_Log_2017-00-19.zip
- (953 Bytes) Downloaded 1009 times
Yeap, I see it doing a faiure in logs at
Admon Alarm (Found) Executed faild for MonitorAdd function
I will look into that
Major updates to ADMON
https://delivery.shopifyapps.com/-/34dc ... 3523ec7957
1.0.0.94 in now the current build
