Add app fails
Add app fails
Anyone experiencing the Add APP box not adding an application when you use it?
First try to relaunch the LT console as "run as administrator" and then retry adding apps. Did this have any effect?
Also post any other add app issues you may see.
IT-Kompass
Re: Add app fails
Post by IT-Kompass »
I get the error "execute process error - system couldn't find the file" when i try adding an app on the Labtech Client.
Restarting as Administrator doesn't change anything, but when i start the Labtech client directly on the Server it works.
Thanks,
Max
Re: Add app fails
If this is version 3 of plugin please verify that you have a c:\temp folder on the Tech console system.
IT-Kompass
Re: Add app fails
Alright, got it.
After executing the batch in C:/temp, choco was installed and now it works.
Somehow i thought you didn't need to install it on the client.
Thanks for the help.
Max
