Removing application
tuxarn
Post by tuxarn »
Hi !
I added a application from the global manager and decided later that I wanted to remove it but I don't think that the change replicated correctly to the computer manager view.
It leaves a blank row for the removed application.
Re: Removing application
The blank row denotes the separation between "Approved Apps" and apps installed using chocolatey.
Example, You approve and deploy winzip, so Winzip shows at top of list. The user manually adds chrome from the command line, not using plugin. Plugin will scan agent and see chrome installed by chocolatey and will add that app to list putting a break between the approved apps and seen apps.
We are improving the split with some colors and disabling the check boxes in next build.
