7 day trial...
BMirsky
7 day trial...
Post by BMirsky »
Trying to activate a 7-day trial. I got the latest.zip from the DOWNLOADS link on support... installed... restarted Db agent... closed and opened console... but I'm getting a Patch Remedy expired on Expired message.
Thanks!
Re: 7 day trial...
Private message me your LT server address and I will get you fixed up.
craigitsg
Re: 7 day trial...
Post by craigitsg »
I am having this same issue. Does the 7 day trial still exist?
Thanks!
Re: 7 day trial...
On first use it may show as expired, close the window and restart Patch Manager.
xedric
Re: 7 day trial...
Post by xedric »
Is the 7 day trial still working? Wanted to try this out but keeps saying expired. Tried to install it twice now.
Re: 7 day trial...
WHat is your LT server name?
iternalnetworks
Re: 7 day trial...
Post by iternalnetworks »
I just installed the plugin to try it out for the 7 day trail and it immediately told me that "Patch Remedy expired on Expired". Can you update to allow me to test it out? My LabTech server address is labtech.iternalnetworks.com.
Thanks.
Re: 7 day trial...
ok you should be all set
iternalnetworks
Re: 7 day trial...
Awesome. It's working now. Thank you. Looking forward to testing it.
