Repairing
MrRat
Repairing
Post by MrRat »
Why on the Hotfix Issues tab do I get an Attempt Repair option and on the Critical Issues tab I instead get MK Patch Fix?
And what is an MK Patch Fix?
Why can I not select multiple agents on both the Hotfix and Critical tabs?
jmassey
Re: Repairing
Post by jmassey »
I can't speak for your other questions here's the info on the MK Patch Fix. BTW this can be found by clicking on the ? icon to the lower right of the SquidWorks Icon on the main window
MK Patch Fix (Derived by Martyn Keigher)
This patch fix process was conceived of by Martyn to assist in systems that are continuously failing patching. This command assigns a LT script to run that will execute several commands.
1) Reimports a Certificate associated with the (97817950D81C9670CC34D809CF794431367EF474) fingerprint.
2) Stops the wuauserv service and the cryptsvc service
3) Removes C:\windows\softwaredistrobution folder
4) Removes the c:\windows\system23\catroot2 folder
5) Restarts the stopped services
6) Resets Windows Updates to Default
7) Resends all installed patches for system
8) Pushes a reinstall of all approved patches
Re: Repairing
Yes thats was a fix provided by Mr.M that we implemented into our systems as a fix option.
