Windows 10 Updates and Builds
Posted: Thu May 25, 2017 1:03 pm
Patch Remedy currently can only get you up to Build 1607 through automation. As Microsoft releases technical updates we will incorporate them into Patch Remedy's automation processes.
The Latest Version of Windows 10 is 15063 A.K.A "Creators Updates". To install these update you must download the Upgrade Assistant and manually run the updates. This will upgrade Windows 10 to 15063.
To learn more about Windows 10 Upgrade paths and Version Builds Visit https://docs.microsoft.com/en-us/window ... s-overview
To see which version of Windows 10 your device is currently running, select the Start button, then select Settings > System > About.
Visit Windows 10 New Creator Updates at https://support.microsoft.com/en-us/ins ... ors-update
Download and execute the Windows10Upgrade9252.exe file and follow the instructions.
https://www.microsoft.com/en-us/softwar ... /windows10
About the Upgrade Assistant
https://support.microsoft.com/en-us/hel ... -assistant
