Having trouble
gproteau
Having trouble
Post by gproteau »
New to using Patch Remedy. Trying to learn the best steps or order of steps to take and having trouble. I have a machine that is missing 1 critical patch. I have run Attempt repair, WUA update (as it is not the current version listed). I have also run Force host to patch now and push WUA updates to host. I have rescanned and restarted the machine in question. But it has not updated to the current version and has not patched the 1 critical patch as of now.
Is there a best practices guide? How do I figure out which patch is not applied on the host? I have only run scripts against a few hosts but no changes have be made to any of them. If anyone has advice I would greatly appreciate some guidence. We are running version 1.0.3.62
