DataGridView Sorting
MrRat
Post by MrRat »
The first column, which appears to be powered on state, when the header is clicked on it shows up and down arrows but doesn't actually sort.
In grids with the second column being RB that column does not show arrows and does not sort.
Re: DataGridView Sorting
In VB , I cannot sort on a image column.
MrRat
Post by MrRat »
oh yeah, duh. that would throw the automatic sort off.
if you were doing the sort in code you could use a hidden column to hold the value represented by the image and sort on the hidden column when the image column's header was clicked. but that would be pain.
