If automated check boxes do not stay checked
Posted: Fri May 19, 2017 3:27 pm
you have build 2.2.2 or just upgraded from 2.2.2 to newer and the checkboxes for workstation and server automation will not remain checked when you close and reopen plugin.
TO Fix: Check all 4 boxes first (at same time) then uncheck what you do not want. Close and reopen and it should now be checked correctly.
From this point any changes will show correctly.
