Release build 1.0.16
Posted: Tue May 16, 2017 6:24 pm
https://delivery.shopifyapps.com/-/e0a7 ... 15eb326faf
This build does several big bug fixes with Yum updates, a must get update.
Re: Release build 1.0.16
Posted: Mon May 22, 2017 12:44 am
by beaver9999
Thank you for the update. Unfortunately I still call install individual updates. Just all Patches. Also, with this update I'm experiencing anew issue. The Linux Update Manager appears twice in the View Menu and in the Plugins Tile for a Linux device.
- Appears twice.
- Linux Update Manageer .png (19.21 KiB) Viewed 30813 times
Posted: Mon May 22, 2017 3:16 pm
Did we update over an existing plugin making not equal to LUM? I bet you have updated a plugin starting with the letter "A" and have overwrote it with LUM. Is the first plugin in your list the same version number as LUM?
Posted: Mon May 22, 2017 6:01 pm
by beaver9999
We upgraded over the 1.0.12 Linux Update Manager plugin.
Posted: Tue May 23, 2017 2:04 pm
Is the first plugin in your plugin manager the same version number as 1.0.16 ?
Posted: Tue May 23, 2017 2:55 pm
by beaver9999
No. The first plugin in the list is version 1.0.14.0
Posted: Tue May 23, 2017 6:51 pm
Go ahead and disable the first plugin in list and relaunch the LT console. does 1 of the 2 tiles disappear?
Posted: Tue May 23, 2017 9:15 pm
by beaver9999
I disabled the first Plugin (Active Directory plugin) but the Linux Update Manager still appears twice.
Posted: Wed May 24, 2017 1:01 pm
Ok email
helpdesk@plugins4automate.com which will open a ticket for me. I will send over a remote session request and a few times I am available. We can pick a time for us to connect and look at this problem further.
