Release build 1.0.16
https://delivery.shopifyapps.com/-/e0a7 ... 15eb326faf
This build does several big bug fixes with Yum updates, a must get update.
beaver9999
Re: Release build 1.0.16
Post by beaver9999 »
Thank you for the update. Unfortunately I still call install individual updates. Just all Patches. Also, with this update I'm experiencing anew issue. The Linux Update Manager appears twice in the View Menu and in the Plugins Tile for a Linux device.
Appears twice.
Appears twice.
Linux Update Manageer .png (19.21 KiB) Viewed 30802 times
Did we update over an existing plugin making not equal to LUM? I bet you have updated a plugin starting with the letter "A" and have overwrote it with LUM. Is the first plugin in your list the same version number as LUM?
beaver9999
We upgraded over the 1.0.12 Linux Update Manager plugin.
Is the first plugin in your plugin manager the same version number as 1.0.16 ?
beaver9999
No. The first plugin in the list is version 1.0.14.0
Go ahead and disable the first plugin in list and relaunch the LT console. does 1 of the 2 tiles disappear?
beaver9999
I disabled the first Plugin (Active Directory plugin) but the Linux Update Manager still appears twice.
Ok email helpdesk@plugins4automate.com which will open a ticket for me. I will send over a remote session request and a few times I am available. We can pick a time for us to connect and look at this problem further.
