Release Build 1.0.14
https://delivery.shopifyapps.com/-/904b ... aba34fa95b
Further fixes issues with Redhat/CentOS Reboot flags.
beaver9999
Re: Release Build 1.0.14
Post by beaver9999 »
I have installed the Linux Update Manager (thank you for making this by the way). Unfortunately, for me the only OS it will update is Ubuntu 16.04. I have LabTech 11 Agents installed on the following OSes but none of them will update...Centos 6, Centos 7, RedHat 7. It will successfully scan for the required updates, but when I try to install an individual update it does not work.
Is there a setting I need to enable in Linux to allow the updates to proceed?
Any assistance is much appreciated.
Thank you
Ok so your seeing packages for Redhat, etc.. just can't select 1 package and update. If you selected "Update all" does it do that for you?
beaver9999
Just tested that (on CentOS 7). It can successfully install ALL patches. Just not when choosing individual patches.
Perfect, let me look into that.
