Plugin Fails to Download Scan Software
t.donovan
Post by t.donovan »
We just recently installed this Flu-Shot Plugin on our Labtech 11 instance and I have not been able to get it to work just yet. I am checking the logs when I try to deploy the Emsisoft software and I showing Download File failed on the 7za.exe file. I am also showing DownLoad URL failed when trying to check http://dl.emsisoft.com/a2cmd.zip. I tried to access that location and it does not seem to work. I am wondering if the file may have been moved on Emsisoft's end.
Has anyone else had or seen this issue and is there an update or fix for this?
Thanks for you help,
Tim!
Re: Plugin Fails to Download Scan Software
Yeap looks like that link is now broken. Well that was an aging plugin so I guess we go back to the drawing board.
starbucksgold
Post by starbucksgold »
I have confirmed that access to the a2cmd.zip from dl.emsisoft.com is still a valid download. There could be something else at play here. Can you send screenshot of the script results from one of your agents.
-Jeff
Return to “Flue Shot AV Plugin”
