Bug / UI columns / Sorting behavior
AJB703
Post by AJB703 »
Various columns in the PatchRemedy GUI don't sort data correctly.
i.e.:
Hotfix Issues > "Systems that have had errors during installation of patches" > Numbers in error column
Critical Patch Issues > "Systems that have not patched in 30+ days" > Dates in Last Patch Date column
Critical Patch Issues > "Systems missing 'Critical' Patches" > Numbers in failures column
Missed Windows > Numbers in Missed Patch Windows column
It is working as expected in a couple of other locations, so it doesn't appear to be GUI-wide.
i.e.:
WUA Versions > "Current WUA Max Versions" > Numbers in Computer column sort properly.
Patch Success > "Systems that have successfully installed patching" > Dates in Last Patch Date column sort properly.
starbucksgold
Re: Bug / UI columns / Sorting behavior
Post by starbucksgold »
Thank you for the feedback. This has been confirmed to be an issue on additional systems and will be resolved in future updates.
Jeff
What version of Patch Remedy are you both using?
Reason, I can not duplicate that issue in .41 or newer
See images:
Missing Windows sorted by number of misses
Critical Patches sort by date and number
Hotfix issues sort by number
Ah the old oneies, twoies issue
i.e. - 1, 11, 2, 24, 3, 33, etc. vs 1, 2, 3, 11, 24, 33.
Hmm... lets see what we can do with that.
