Window Resizing Question
howardr
Post by howardr »
Powershell Version 2.1.5
Labtech 10.5 Patch 11
Is it possible to resize the entire window?
Right now it's set to 80, I can change the buffer size to get better outputs, but I'd like the ability to change the windows size.
Re: Window Resizing Question
No but we can look into that
howardr
Post by howardr »
Thank you. That plugin has made my life so much easier.
