ESX Alerting
bcockrell
ESX Alerting
Post by bcockrell »
We have enabled alerting for the monitor. The internal monitor was created. Right now one of the hosts is reporting an error but we have not gotten an alert. How do we setup the alerting?
Re: ESX Alerting
OK, Here is the basics.
Open the Internal Monitor and verify that the configure tab is set as so.
Go to Alerting Tab and select an Alert Template to use or modify.
If the Alert template is already what you need your done. Else modify an Alert template
Editing a template allows you to add alert types like emails, ticketing, alarms, and so on...
Check your Query results to see what is being picked up. If you're seeing errors in your logs Main View of the ESX Monitor and not seeing it here then post back what you are seeing with screenshots.
Re: ESX Alerting
:::Update:::
As of build 4.0.0.30 the monitor has changed to a RAW SQL monitor. Anyone upgrading above 4.0.0.30 should disable the monitor in the plugin and then re enable the monitor to update the monitor after the plugin upgrades.
