Released build 1.0.3.36
Posted: Mon Nov 28, 2016 3:58 pm
Re: Released build 1.0.3.36
Posted: Tue Nov 29, 2016 2:32 am
by BlairMunro
Hi Cubert, what has changed in this version? Thanks!
Posted: Tue Nov 29, 2016 2:40 pm
You can find change notes in the README.txt file included with our plugins. In the case of this update we have updated the following.
We have turned on Multiple select for the following view. This allows you to select all the systems you want at once and push out the latest updates only. All other tools listed are still only 1 on 1 runs meanings you select a single system from list and that system gets the commands you send.
(Multi Select agents for updates)
- 12.png (145.74 KiB) Viewed 13921 times
Posted: Thu Dec 01, 2016 11:25 pm
by BlairMunro
Cheers Cubert, love your work!
Posted: Fri Dec 02, 2016 2:35 pm
by starbucksgold
Shannon,
I've confirmed the multi-select works great on the WUA versions tab
Would love to the same option (multi-select) added to the other tabs if possible.
Jeff
