Released build 1.0.3.36
Here is the build 1.0.3.36 https://delivery.shopifyapps.com/-/69ee ... 1284566481
- 9
Re: Released build 1.0.3.36
Hi Cubert, what has changed in this version? Thanks!
You can find change notes in the README.txt file included with our plugins. In the case of this update we have updated the following.
We have turned on Multiple select for the following view. This allows you to select all the systems you want at once and push out the latest updates only. All other tools listed are still only 1 on 1 runs meanings you select a single system from list and that system gets the commands you send.
(Multi Select agents for updates)
- 9
Cheers Cubert, love your work!
- starbucksgold
- 9
Shannon,
I've confirmed the multi-select works great on the WUA versions tab
Would love to the same option (multi-select) added to the other tabs if possible.
Jeff
Jeff
