Adobe Acrobat fails installs with checksum error
Posted: Thu Nov 03, 2016 5:16 pm
If you find systems are not deploying Adobe Reader or Shockwave, you may have the checksum option turned on for that agent. Turn off require checksum with allow package to install.
Looks like maintainer did not create a checksum for this package.
To turn on and off CheckSums go to Client Console.
