choco.exe renames itself?
Posted: Fri Oct 14, 2016 5:44 pm
by nate.crist
I have a workstation where chocolaty starts out working fine, but then choco.exe renames itself into choco.exe.old and another file is made called choco.exe.old?
I removed Chocolatey compleatly and re-installed and again, it started out fine, but then an hour or so later, it had renamed itself again. Any explanation for this?
Re: choco.exe renames itself?
Posted: Mon Oct 17, 2016 1:28 pm
Is there still a choco.exe file in the root and in the ./bin folder after renames?
if you to a properties on both files are they the same version #?
Just making sure we are not seeing Choco updates.
Posted: Mon Oct 17, 2016 1:31 pm
I am seeing the same inside our deployments in the bin dir. Date happened on same day but only once.
