choco.exe renames itself?
nate.crist
Post by nate.crist »
I have a workstation where chocolaty starts out working fine, but then choco.exe renames itself into choco.exe.old and another file is made called choco.exe.old?
I removed Chocolatey compleatly and re-installed and again, it started out fine, but then an hour or so later, it had renamed itself again. Any explanation for this?
Re: choco.exe renames itself?
Is there still a choco.exe file in the root and in the ./bin folder after renames?
if you to a properties on both files are they the same version #?
Just making sure we are not seeing Choco updates.
I am seeing the same inside our deployments in the bin dir. Date happened on same day but only once.
