Set as Scanner not functioning
RWtechnologix
Post by RWtechnologix »
I recently installed the newest version of this plugin. I deployed the MSOL modules per your YouTube video. When I click Set as Scanner it runs through the check again and sees that the modules are installed, but it shows the scanner as Not Configured and red lights for both the Modules and Online.
Re: Set as Scanner not functioning
if you closed the config and reopen it does it still show red?
The Set scanner should set that as soon as you select button.
Select a scanner then click Set as Scanner button will automatically start off with changing the colors to green during the install process as seen below. This does not happen for you? What is returned in the terminal box during update?
Should get something like:
Checking For Azure Module Deployments on P4L-LT11-DC (1)
MSOL Modules maybe missing, Installing Modules on P4L-LT11-DC (1)
Uploading commands
Executing commands
Installing AZURE Modules  - Installed
Installing Administration Config  - Installed
Installing Sharepoint Management Shell  - Installed
Installing Skype For Business Modules - Installed
The current Sharepoint Shell module version installed is 16.0.5326.1200
After about 2 minutes of run time it should be completed and you can then turn on the plugin...
