Released Build 1.0.3.10
Here is the build 1.0.3.10
https://delivery.shopifyapps.com/-/020e ... 34522a6a1e
---Build 1.0.3.10 ---
Updated the maintenance script to manage retention better
Added scanner interval configuration to control the number of scans for backups which are done daily.
Modified the Computer console screen look
Updated the help text
updated the license management process
Renamed the plugin DLL file and name listed in plugin manager
