Multiple Issues
Posted: Wed Sep 28, 2016 4:26 pm
by darsveen
I've got a few issues going on with Chocolatey for Labtech.
First issue, the plugin is duplicated on the view drop down and on the individual agent tabs.
Second issue, when I open the plugin from the view drop down I receive a script error.
Third issue, I've updated the plugin to the latest 2.0.1.80. It shows correct in the Plugin Manger, but still shows 2.0.1.75 when I open the plugin from the view tab.
Fourth issue, one off installs don't work. When I look at the command logs it's not calling the package name entered, instead it's duplicating the install variable. Here is what the cmds look like: Parameters: cmd!!! /C "C:\ProgramData\chocolatey\bin\choco.exe" install -fy instal
I've attached screenshot of all the mentioned errors.
Re: Multipule Issues
Posted: Wed Sep 28, 2016 4:27 pm
by darsveen
Re: Multiple Issues
Posted: Thu Sep 29, 2016 1:21 pm
Ah yes the dreaded plugin overwrite issues with LT plugin manager. First off not sure is it was patch 3 or patch 6 that fixed that in LT10.5 but you may want to look at LT patches to see if your up to date.
What has happened is during a install or update you (your LT admin) have done is accidently overwritten another plugin with the chocolatey dll. LT had a problem that if you didn't select the correct plugin first from the plugin manager list before selecting update plugin then what ever plugin was selected at that time was overwritten with the plugin you were updating.
So How to Fix!
Open plugin manager and look at all the version numbers. Find any plugin that has the same version number as Chocolatey but has a name of something else. Disable and delete that plugin from Labtech, restart the DBagent and your local console.
See if the duplicate entry is now gone.
Next Issue, the Script failure.
This is most likely a bad data point in the database causing the java graph(chart) to blow up. Post a image of the metric tab that holds the graphs so I can see which one didn't load. I can then tell you what database table to look at for bad data. remove bad row should solve script error.
Re: Multiple Issues
Posted: Thu Sep 29, 2016 1:24 pm
Lastly Chocolatey is now on Build 2.0.1.80 so you may want to update the plugin aswell. See our Release Build post in this forum to get DownLoad link
Re: Multiple Issues
Posted: Sun Oct 02, 2016 6:25 pm
by darsveen
OK, I got the duplicate plugins issue corrected.
Is this the screenshot you are looking for?
Re: Multiple Issues
Posted: Mon Oct 03, 2016 12:38 pm
Yes sir, The top graph has blown up and I see the bottom graph has bad data as well.
My suggestion is to flush the plugin_sw_chocolateyii_installed_apps table, removing all data and allowing the latest chocolatey scanner updates rebuild the table data.
This should clear things up for you, if your still seeing this afterwards send us a email at helpdesk (@) plugins4labtech.com and that will open a ticket with us. Make sure to post images and issue again so we have you documented.
