VMWare ESX Health Monitor 4.0 Releasing Soon!!
Posted: Thu Aug 18, 2016 8:44 pm
Oh Yea!!! Everyone loved the 3.0 Version of the plugin but it was kinda hard to get going if you are not a LabTech geek. That all changes with 4.0!!
We have rebuilt the plugin from the ground up and this one is Awesome! Just install the plugin DLL and away ya go!
Here whats coming:
Client console controls the addition and removal of ESX Hosts and allows you to set multiple probes for different hosts or dual probes for redundancy.
The Main [View Menu] manager shows your systems current states, activates the probes, manages the probe intervals and turns on and off the monitor.
Cim Data can be seen by selecting the View CIM data from any ESX Host in the lists.
When you activate the monitor you will find it in Internal Monitors ready to pick up failures and create alarms.
Everything is automated, you need no supporting files. just agents ready to be a probe.
I will be releasing this in the next week if all goes well in beta!
Cubert :ugeek:
Re: VMWare ESX Health Monitor 4.0 Releasing Soon!!
Posted: Fri Aug 19, 2016 5:38 pm
by starbucksgold
Shannon,
This looks good. I will certainly install and test. We are transitioning to a new office building over the next 9 days. I have a lot going on from an operations standpoint, but will still find time to play :)
Looking forward to checking this out.
Jeff
Posted: Fri Aug 19, 2016 5:40 pm
Should auto license for 7 days.. when you launch it the first time. Let me know if it does not.
