Master switch doesn't stay "on" after exiting plugin
Posted: Mon Aug 15, 2016 8:15 pm
by kenneth.knowles
When I switch Patch Remedy on, it doesn't stay on. If I exit the plugin and then reenter the plugin, the master switch (and all the switches) are off.
Am I doing something wrong, or is that the expected behavior?
Re: Master switch doesn't stay "on" after exiting plugin
Posted: Tue Aug 16, 2016 2:55 pm
The switches go off if license is invalid. So either the LT server name is not matching your license name or you server/LTconsole can not access
www.plugins4labtech.com.
99% of the time it's a mis match LT server address. I sent you a email on this with a request for your server name. Shoot that over to me and I will get you fixed up.
