When I switch Patch Remedy on, it doesn't stay on. If I exit the plugin and then reenter the plugin, the master switch (and all the switches) are off.
Am I doing something wrong, or is that the expected behavior?
Master switch doesn't stay "on" after exiting plugin
- 9
Re: Master switch doesn't stay "on" after exiting plugin
The switches go off if license is invalid. So either the LT server name is not matching your license name or you server/LTconsole can not access www.plugins4labtech.com.
99% of the time it's a mis match LT server address. I sent you a email on this with a request for your server name. Shoot that over to me and I will get you fixed up.
