Build 1.0.3.24 Release
Posted: Thu Aug 04, 2016 4:15 pm
Time to get a handle on all these systems pending reboots after WUA updates or patches go out.
Today we released that function out inside of Patch Remedy. When "Pre Maintenance reboot" flag is set, any client under patch remedy maintenance and not on the Patch Remedy Excludes list will be inspected for pending reboots at the very beginning of their maintenance windows. All conditions must be met for the reboot command to be sent to systems. If any location is using the “* Disable All Alerting” Window then we skip that location.
A system must:
Be under PR management and not excluded
Be Windows
Be “pending a reboot”
Be entering maintenance mode
Be in a Location not set to “Disable All Alerting”
Maintenance window time frame is set to (only) Alerts off flag
www.plugins4labtech.com
How cool is that!! :ugeek:
