Password Set
Posted: Wed Jul 27, 2016 1:42 pm
by revsmitty
First, thanks for all the other fixes you implemented.
My co-worker was trying to add a user via the plug-in yesterday and was curious why isn't there a way to set the users initial password upon creation.
Is there something we are missing or do we need to create the user then click reset password.
Re: Password Set
Posted: Thu Jul 28, 2016 1:12 pm
Correct, That's a good point though. I will look at that and see what we can do to add that in as part of the add user.
