Build 1.0.3.12 Bug Fix update!
We released a new build last night after finding a bug in the code that was preventing the WUAMAX table from updating correctly. We also added in a "CheckBox" on Configure page to account for MSPs that are upgrading to LT11 but are not yet upgrading patching processes. (I.E staying with 10.5 patching functions). This toggle will counteract the plugin seeing LT11 as the Host and will not change queries over for LT11 patching.
The build is 1.0.3.12 and should of updated for most of you last night. To validate you have the latest build close and reopen your LT console and launch the Patch Remedy console. The build number is in the header of the console.
We are working on adding in the feature for the ability to adjust the clients computers that are being scanned and included inside of Patch Remedy. This will be in build 1.0.3.14 due out shortly (next few days). It will be backwards compatible with just the client selections but you will be able to add excludes to each client you enable removing that information from Patch Remedy views.
Good stuff in the works!
