How to setup custom graphs
Posted: Mon Jul 18, 2016 5:42 pm
Custom graphs can be added to Magma when you create new monitor scripts.
Let's say you created a remote monitor that is querying the weather temp and wind speed and wanted to also graph that data. You will need to have SSH access to your Magma server which you do by selecting the computer console of the Magma host and using the network redirector. You will need to be able to edit text files on the Magma server using VI.
You magma server working directory is /var/www/magma/server
Now use the following how-to to make the adjustments needed to make your test graph.
How to create your own custom graphs.
https://www.xymon.com/help/howtograph.html
