LabTech 11 Support?
coriron
LabTech 11 Support?
Post by coriron »
Hi guys. What's the latest regarding LT11 support for Chocolatey plugin? I had to remove chocolatey from my server when we were upgraded because it flooded our server with script logs. Unfortunately i'm now not in a position to send those log files over as we are cloud hosted, so i do not have access to it.
What i can say is that i've tried to re-install the latest version and got the following error:
Error Uploading Plugin
There was an error uploading the new plugin: Could not load file or assembly 'file:///D:\Users\pacitadmin\AppData\Local\Temp\3\tmp7EA3.tmp' or one of its dependencies. Operation is not supported. (Exception from HRESULT: 0x80131515)
OK
Re: LabTech 11 Support?
We are doing final testing now, our latest version should be released this week.
We are using Chocolatey 2.0.1.51+
Here is Chocolatey Installs on LT 11
Chocolatey services running on LT 11
Client Level Installs on LT 11
Computer Plugins View LT 11
Computer Level Installs on LT 11
coriron
Post by coriron »
awesome. thanks!
coriron
Post by coriron »
Any update on this Cubert?
coriron
Post by coriron »
oh, i've just checked the plugin and its on version 2.0.1.62, so i assume that means its ready :D
We have had several updates yes, build .62 is the latest.
if you want to see what was updated, grab the latest download and in the zip is a read.me file that has build change notes.
Did so updates to the back end to make it faster getting through the jobs, made some updates to the scripts, added a few new tidbits. several bug fixes..
:ugeek:
