Released Build 1.0.2.90 (Big Updates)
We just released a major update to Patch Remedy (1.0.2.90)
----Update----
Bug fix, SQL error during ISync for CheckforUpdateErrors where filed was misspelled
Added Manual Scanner feature with pop out progress window
Added Refresh Views button to refresh all of Patch Remedy data with one click.
Removed WUA Refresh button
Removed Patch Error Refresh button
Removed WUA OFD text under Configure tab
Adjusted Visual displays
Updated WUA Query to improve load times and not time out
The big one is we added a new method to calculate 'out of date' WUA which now only takes a second versus the the old way which sometimes times out for MSPs with large agent counts. We also added some new features to the Configure tab so you can get data flowing fast. This should solve alot of issues being reported by members.
You should auto update over the weekend so remember to restart your LT Consoles on Monday to get the new plugin in your LT Control Centers.
http://patchremedy.plugins4labtech.com/ ... hp#support
Enjoy
Cubert :ugeek:
