Reporting 100% Systems WUA UpToDate Not Accurate
- 9
Good morning,
I have installed the latest version of Patch Remedy 1.0.1.22 and I am just looking over some of the features and it appears that the Systems WUA UpToDate is not accurate.
The gauge is showing 100% on the overview screen but going to the WUA Versions tab I am showing 20 computers with WUA out of date.
What do I need to do to get these to accurately reflect each other?
Thank you,
Alex
Thank you,
Alex
- System WUA UpToData.png (9.11 KiB) Viewed 32525 times
- Reporting Out Of Date.png (2.23 KiB) Viewed 32525 times
Re: Reporting 100% Systems WUA UpToDate Not Accurate
I am in the same boat
Both of you are using 1.0.1.22 correct?
Run this on your LT server in SQL an see what we get returned.
Create Temporary Table Tcomp(SELECT * FROM plugin_sw_patch_remedy_wua Where WUAVersion Not IN (Select Distinct max(WUAVersion) FROM plugin_sw_patch_remedy_wua GROUP BY OS) And RemedyAttempts < 3);Select round(100 - ((Select count(ComputerID) from TComp WHERE ComputerID IN (Select ComputerID FROM computers WHERE LastContact > date_add(now(),interval -5 minute) and ClientID IN (Select ClientID FROM `plugin_sw_patch_remedy_config` Where MasterSwitch = 1)))/(Select count(computerID) from computers where OS like '%windows%' and ClientID IN (Select ClientID FROM `plugin_sw_patch_remedy_config` Where MasterSwitch = 1))* 100))as Percentage;drop table TComp"
1 queries executed, 0 success, 1 errors, 0 warnings
Query: drop table TComp"
Error Code: 1064
You have an error in your SQL syntax; check the manual that corresponds to your MySQL server version for the right syntax to use near '"' at line 1
Execution Time : 0 sec
Transfer Time : 0 sec
Total Time : 0 sec
Error Code: 1064
Total Time : 0 sec
wdyoung wrote:1 queries executed, 0 success, 1 errors, 0 warnings
Error Code: 1064
Total Time : 0 sec
Yea I copied the " when i pasted to forum post, take out the last char -> " and re run
I am in the same boat as the rest. WUA Versions and Hotfix issues are not reporting. (would be nice if that were true)
This issue is the Up to date Gauge showing 100 % when 20 + systems show out of date.cmenard01 wrote:I am in the same boat as the rest. WUA Versions and Hotfix issues are not reporting. (would be nice if that were true)
Lets open a new thread if you have data missing else where so we don't get confused to what we are trying to fix.
You need to set the scan interval, select the clients to scan and save that first. Then turn on the master switch to get started scanning. It will take the course of your interval setting to complete the first scan. So if you set it for 8 hours, you will need to wait up to nine hours for first data to arrive. If this doesn't help post a new thread with the issue and any screen shots you can show. Also post a screenshot of the configure tab when posting.
<e>Query: Select round(100 - ((Select count(ComputerID) from TComp WHERE ComputerID IN (Select ComputerID FROM computers WHERE LastContact...
Error Code: 1146
Table 'labtech.tcomp' doesn't exist
Total Time : 0.001 sec
Error Code: 1146
- 9
Ran the query and removed the " and getting the same error ad wdyoung.
Error Code: 1051
Unknown table 'tcomp'
Total Time : 0 sec
Error Code: 1051
Total Time : 0 sec
If you were running a prior version of Patch Remedy 1.0.0.5 or older then delete your tables for Patch remedy and restart the DB agent to rebuild new tables. Also at same time delete the old scripts for Patch remedy in the Maintenance folder and allow that to also get rebuild by plugin.
