ISCSI Targets supported?
One question, we do backup with an ISCSI target and it's already setup on all our servers. Would this be supported by your plugin ?
Yes it would be, Any drive letter or disk volume can be used as a target. We in fact would suggest anywhere you have servers that you use direct attached storage that Windows will see as local. Allows all the backup features to be available to you.
