Release 2.0.1.41 now available
Squidworks has now released build 2.0.1.41 which has added new features.
Available at http://chocolatey.squidworks.net/support/
We added a new feature to control how new apps are enabled across and deployed environment. The new Auto Enable allows you to set all system to allow the install of the the approved application your adding to your approved application list. By default the application is excluded from install to all systems.
We have now added tool tips messages on most controls to help define what a function or button does.
We now set by default to off the master switch anytime the "Add common apps to list" control is used. This it to prevent a mass install of software that may otherwise was not wanted. Once you have reviewed the list you can turn on the master switch again.
We fixed a display issue in the approved apps list where as admin would show as on for all apps that displayed under a app that had the switch to on. this was a display only issue and in now not an issue.
