What "Permissions" are required to open the Patch Remedy Pluggin
nate.crist
Post by nate.crist »
Our normal level users are unable to open the Patch Remedy Plugin. What Permission level is required to open the plugin?
Thanks,
gdas-geno
Re: What "Permissions" are required to open the Patch Remedy Pluggin
Post by gdas-geno »
Add the 'Patch Remedy' User Class to the labtech user:
PatchRemedy User Class.png (42.74 KiB) Viewed 9254 times
nate.crist
Thank you very much!
