Can't Install Patch Remedy
GoVanguard
Post by GoVanguard »
Hey there,
When I go to Add Plugin and select the Patch Remedy DLL I get an error prompt stating: "There was an error uploading the new plugin."
PlugIn hasn't been installed previously and I don't see any tables for plugin_sw_PatchRemedy in the database. Any ideas?
-M
Re: Can't Install Patch Remedy
Right click the DLL file and select properties, click the unblock button on main properties window.
chris
Post by chris »
I'll just add that I was having this problem too, even after trying the unblock option. If you're trying to install from the LT server locally, try installing from a different machine (or vice versa). Worked for me. Best of luck!
Yeap, Not sure why a system wants to resist the installer... this just started recently in the last year with 10/10.5
mitmit
Post by mitmit »
chris wrote:I'll just add that I was having this problem too, even after trying the unblock option. If you're trying to install from the LT server locally, try installing from a different machine (or vice versa). Worked for me. Best of luck!
Same process worked for me, too. Thank you for sharing.
Actually if you just close and reopen console, no matter where, it will install after a re launch of lt console after a unlock.
Good luck!
