I noticed on my machine I have spotify installed and it looks like its installed in my profiles appdata location.
Its wildly out of date even though an update looks like it ran an hour ago.
How do we see why its not updating that app?
App Genie 1.0.0 Overview
MarkHodges
- 7
Re: App Genie 1.0.0 Overview
Feature Request: Be able to type in partial name of app and have a search button that finds all the chocolately packages related to that name.
aka, I type in utorrent% and search and it tells me if there is a package for that name and obviously what the package name is.
I had to go lookup in the website what the package was (although it was as I was going to guess).
be even cooler if you could somehow run a report against a machine, and it would auto try and find an existing packages that exist for those apps...when you could click and add them that way vs doing it manually...
Not sure if I'm doing something wrong or just being impatient but this doesn't appear to be working correctly for me. I installed the plugin, reloaded DB, refreshed my cache. Initially, no workstations showing up after checking the enable workstations box. No log either. Reinstalled plugin from CWA server, I now see a log about the client I checked the enable workstations box for previously. I do not see any list of software for any of these agents. I went to a different site, clicked enable workstations and 10 min later still no workstations showing up for this site. No activity in the log since reinstall and it scanning that first site... What am I doing wrong?
Patients young grasshopper,
Automation is set to the top of the hour so allow a few hours for everything to start to populate.
I'm seeing a lot of the below error when I look through the
The remote server returned an error: (429) Too Many Requests. Too Many Requests
Is this SQL errors? Where are you seeing theses?
We just released build 1.0.19.0
http://support.plugins4automate.com/dow ... 250e614a4e
We added a new control in the global manager section to control how often the automation runs.
Using the KISS method, there are 2 current options available (Fast and Slow)
Fast is what you currently have now in 1.0.18.0, 1 of 3 functions runs every hour.
Slow is each of the 3 main functions runs only once per day and does it all before 7 AM.
Click on the Rabbit/Turtle icon to flip between fast and slow scan speeds.
Looking at the automate command history
Ah, maybe we need to slow down the script executions some. I will look into that.
We just released build 1.0.20.0 which adds a sleep between updates to assist in the reported error.
http://support.plugins4automate.com/dow ... 728f6cc165
