App Genie 1.0.0 Overview
Re: App Genie 1.0.0 Overview
We just released Build 1.0.14.0
Added a version comparing area for apps installed.
Also fixed an issue with the update function.
You must drop the Associate table in the database before upgrading to this version.
Open SQL Yog and execute the following line to remove old table
DROP TABLE plugin_p4a_app_genie_assoc;
Just released 1.0.16.0 out for Beta
http://support.plugins4automate.com/vie ... f857#p7189
This is starting to square up nicely.
We added several new features including a new Client console menu to have manual control over several key functions.
Have a peek at what we done.
NoPetPigsAllowed
Post by NoPetPigsAllowed »
Just upgraded to 1.0.16 from 1.0.2 and all of the existing Apps that were listed have disappeared. Should this auto populate again or is something screwy going on. ;)
Thank you!
Edit: Looking into the post notes, I see that maybe I should have ran "DROP TABLE plugin_p4a_app_genie_agent_apps;" on the SQL database before upgrading. Can this be verified?
Did you do a Drop table before update?
If not redo this step and then restart the dbagent.
If apps do not show up let us know
NoPetPigsAllowed wrote: Thu Jun 06, 2019 5:39 pm Just upgraded to 1.0.16 from 1.0.2 and all of the existing Apps that were listed have disappeared. Should this auto populate again or is something screwy going on. ;)
Thank you!
Ah looks like we forgot to update the data insert after modifying the table. So now new table is created but data fails insert.
See now we have a 1.0.17.0 !
We just released build 1.0.17.0 fixing the data insert issue above.
You should re drop table again and then restart the dbagent for table and data to be recreated correctly.
Link to 1.0.17.0
http://support.plugins4automate.com/dow ... 54d7a2d992
Thank you!
Yes, but that can be done at any time. Just drop table and then restart the DBagent service on LTHost. That will recreate table correctly and add the updated app list to it.
NoPetPigsAllowed
Cubert wrote: Fri Jun 07, 2019 12:49 pm We just released build 1.0.17.0 fixing the data insert issue above.
Link to 1.0.17.0
Seems to have corrected the issue - thank you Sir!
Awesome,
We do see an issue in .17
Looks like updates happen even if not needed. Will need to look at this code segment and see why it fails to see same versions.
Can anyone else confirm that updates happen even if software is up to date?
We have now solved that issue in 17.
Build 1.0.18.0 now available
download/file.php?id=692
This now resolves issues where update function updated everything no matter if it needed it or not. Now will be much more selective in what it tries to update.
Enjoy.. Think we are getting close to a good release.
Return to “App Genie”
