Page 2 of 4
Re: Calling Beta Testers
Posted: Tue Dec 17, 2019 2:04 pm
Ok retry again (Twice) please, I made some changes to the license API and added a logger for failed responses. Lets see what your turning up.
Posted: Tue Dec 17, 2019 7:11 pm
by smorrow
Getting an error at launch. Not sure if that's related to never actually seeing the File Explorer option.
Missing DLL Files error on downloadAn exception occurred during a WebClient request.
Posted: Wed Dec 18, 2019 1:46 pm
If your local user account for PC is not full admin level then you maybe hitting some permission issues with coping the needed DLL files to the automate console directory. Try running the console once "as administrator" and see if errors go away. Once the google drive DLLs are in the directory the services should be functional.
Send back any screenshots you are still getting afterwards if any.
Posted: Wed Dec 18, 2019 9:52 pm
We just posted build 1.0.0.18 which fixed a bunch of stuff with Announc Maintenance which allows it to work with new patching manager (see video posted in forums)
We also added a new tool, Printer Status Tool (see video posted in forums) with some new updates.
You can get the download back on page 1 of this post. We update that link regularly. The plugin should also auto update automatically so you can let that happen naturally if you like.
Enjoy!
Posted: Mon Dec 30, 2019 2:03 pm
We are going to push beta out another month!!
So everyone should see a license date of 01/31/2020 as of today, Enjoy and thanks for your support.
Posted: Tue Dec 31, 2019 12:55 am
by noverus
Saying expired on my new install as of today.
Posted: Thu Jan 02, 2020 3:44 pm
Should look like so,
If not what build are you seeing? We are on 1.0.0.18
Posted: Mon Jan 06, 2020 9:29 pm
Just released build 1.0.0.19 which adds a new version of Active Directory User Password Expiration Notifier tool. Plugin should auto update.
Posted: Fri Jan 17, 2020 2:53 am
by xenophonix
I have installed Habitat, I can open it and the license shows correctly so I want to test the Windows upgrade assistant but I can't get any policies to save using a web server for the ISO location. I checked the documentation and no matter what I do it won't save. I can click cancel and interact with all of the settings but at no point can I click the save button to save the policy. Is there anything you can suggest?
Posted: Fri Jan 17, 2020 1:55 pm
On your console there should be a Automate console log (C:\ProgramData\LabTech Client\Logs\(DATE)LTCERRORS.TXT
Look inside that to see if you are logging any plugin errors. We are looking for the database queries to be failing.
Question: Have you restarted your DBAgent on the Automate Server yet? If not the Database tables will have not been created yet so any saving will fail as tables do not yet exist. You should then see in the logs a query failure and reference to missing table.
Post that log tidbit here if you have any.
