Page 2 of 2
Re: Unsure what is going wrong
Posted: Wed Sep 05, 2018 3:51 pm
by jmaxwell
We are using the URL scenario. This still needs a network share location set up correct??
We copied the ISO manually since it was quicker and in our testing environment.
As for the rest of the files:
1. See attached for the file path C:\Windows\LTSvc\PatchRemedy Is this the correct path? Correct files downloaded?
2. See attached. Is this all the files needed?
3. Per previous response, the only thing we can determine if the set up ran was the "Windows Installer" process was in the process section of task manager. Would this be the place to look for the setup.exe? Other
Would this be the correct command(s) in the script? See attached.
Also, line 507 is the message we get then line 510 message occurs as in last screenshot of my previous post.
Which command do I need to copy and run in command prompt exactly? Do we know the name of the update app that would be consuming alot of cpu?
Thanks again for support and patience with me.
by jmaxwell
Posted: Thu Sep 06, 2018 2:14 pm
This is the command we run here. Run this command while monitoring the Windows Processes to see what get launched during the setup.
Posted: Thu Sep 06, 2018 8:20 pm
by jmaxwell
Ok tried to run the command as instructed. Here are the results.
C:\Windows\LTSvc\PatchRemedy\windows10UG\sources is where that .dll is found out.
Let me know if I incorrectly ran it. Or need additional information.
Posted: Fri Sep 07, 2018 12:54 pm
Yeap that was correct, the last command with full path...
And we got an error, The files that were extracted are corrupt. so lets step back a bit and test re-extracting the files from ISO.
In powershell run, change @ISO_Path@ to actual path of ISO
$mountResult = Mount-DiskImage -ImagePath @ISO_Path@ -Passthru
($mountResult | Get-Volume).DriveLetter
Next take drive letter returned and execute, change @MountDriveLetter@ with actual drive letter returned above and replace %ltsvcdir% with correct true path. Make sure to delete all files from directory first so robo copy copies fresh.
robocopy @mountDriveLetter@:\ %ltsvcdir%\PatchRemedy\windows10UG\  /e /r:1 /w:1
Once copy completes, (Note how long copy takes) rerun previous install command on setup.exe. Do you get same error?
If not, try setting plugin config setting to copy ISO locally to agent . It maybe that the LTagent script service times out during the copy. it only allows us like 10 or 15 minutes per command.
Posted: Wed Sep 12, 2018 3:32 pm
by jmaxwell
I tried running the first command on two machines. Here is the results.
Do i need the entire path of the iso including the .iso file or just the folder path where the iso is located? Please advise.
Posted: Thu Sep 13, 2018 2:28 pm
Nope your requesting it fine, the issue is your getting "Permission Denied" for the user executing the powershell console.
That is a typical issue that can be resolved by placing ISO on a basic open network share. Shares inside a domain environment must have permissions allowing a user and or the LT agent service user the ability to access files.
