Windows Upgrade Assistant - W11
lblokland
Post by lblokland »
now the new upgrade assistant is here I was wondering how we can use this to upgrade to W11..
As far as I can see there is nothing to select.
Would be nice to set a client and/or location to a specific windows version so that when we schedule the OS upgrade script to run it patches the agents according to that setting.
Please assist to upgrade to W11
Leon
Re: Windows Upgrade Assistant - W11
There will be a Windows 11 Feature update tool soon. The Windows10 to Windows11 upgrades have had some issues with silent launches and how it handles the EULA acceptance required to approve upgrade.
They said there was a bypass switch but when used it does not seem to work and system sits waiting for EULA approval.
lblokland
Post by lblokland »
Allright, looking forward to it!
What about my idea's, are they appreciated or should I put those requests in separate boards/posts?
Absolutely, Lay them on me...
lblokland
Post by lblokland »
Thanks.
Is there an ETA on the W11 upgrade tool?
To be honest we mainly use Habitat for OS upgrades, and now with half of it not working it's pretty expensive.
Cheers,
Leon
lblokland
Post by lblokland »
Hi Cubert,
any news on this end?
My customers would like to upgrade, and I would like not to do that manually :D
Cheers,
Leon
Our problem here is that there does not seem to be any path via automation allowed by Microsoft for Windows 10 to 11.
Ways-to-install-windows-11
There is a known issue with the Accept EULA portion of the available arguments. So it's not possible to run installer fully silent.
So since you must have user intervention, I have added a new menu item to the windows 10 upgrade tool to push windows 11 to logged on consoles only. This function does not do any pre testing of the agent to see if it is compatible with Windows 11. So you will need to do your do diligence.
This allows you to select multiple agents at once and send a script to execute (now) the Windows 11 upgrader via windows upgrade assistant. The script verifies its running on Windows 10 only and that a user is logged into a console of the agent. It then redirects the execution of a POSH script from the users console which will launch the installer and have then accept the EULA. Once that is properly accepted the install will continue silently to completion.
This is the best we can do until Microsoft releases a installer that can be automated.
Habitat build 1.0.1.30
https://delivery.shopifyapps.com/-/6ad6 ... d8b2584b52
Screenshot 2022-10-02 123617.png (47.22 KiB) Viewed 18056 times
Upgrade to Windows 11
Available in Habitat build 1.0.1.30
This is a run now function. Highlight one or more agents from agent list and select this menu item from the main menu.
It will verify agent is windows 10 and that a user is logged in to a console. It will then execute the installer on that console so that user will see the EULA to accept. Once user accepts EULA the install will continue silently.
lblokland
Post by lblokland »
Hi Cubert,
tested this one with succes:
source and credtis: https://community.syncromsp.com/t/windo ... pt/2846/16 :
$workingdir = "c:\temp"
$url = "https://go.microsoft.com/fwlink/?linkid=2171764"
$file = "$($workingdir)\Win11Upgrade.exe"
If(!(test-path $workingdir))
New-Item -ItemType Directory -Force -Path $workingdir
Invoke-WebRequest -Uri $url -OutFile $file
Start-Process -FilePath $file -ArgumentList "/Install /MinimizeToTaskBar /QuietInstall /SkipEULA /copylogs $workingdir"
Oh Wow, I'll get our stuff updated and give it a whirl.
