New purchase - Patch Remedy is Expired
TGSupport
2
Post by TGSupport »
We purchased Patch Remedy last week and it seemed to be working well. However, this morning I'm opening Patch Remedy and it's got an Expired message in the upper right.
What do we need to do to fix that?
Re: New purchase - Patch Remedy is Expired
PM me with you automate hostname and I will have a look.
You will find the name we look for here in the image below.
Dashboard - > Config- Redirect host name
Atomic
1
Post by Atomic »
Same problem I'm having. PM sent.
@Atomic See if your up and running now.
Atomic
1
Post by Atomic »
Looks good now. Thanks!
NathanWilson
2
Post by NathanWilson »
I am also having this problem, can I also pm you please? Was working, now it's saying expired
@NathanWilson you should be good now.
NathanWilson
2
Cubert wrote: Mon Jun 20, 2022 12:42 pm @NathanWilson you should be good now.
Thanks so much!
TGSupport
2
Post by TGSupport »
We are showing Expired again
We let our license lapse but have re-subscribed. I did put our Hostname in our Account settings.
@TGSupport.
Ok we found you under CustomerService@ and see that you renewed Patch Remedy 4.
We canceled that subscription and updated it to Patch Remedy 5, You might get a notice in email of cancelation.. Ignore it.
Get 1.0.5.11 here
https://delivery.shopifyapps.com/-/3f26 ... c92f077283
Install it and launch it.. It will come up expired! that's OK.
It will have added your Automate host to the license system and afterwards we can search and find it and enable it.. From this point afterwards it will auto renew based on your account activity.
Send me a email at support@plugins4automate and let me know you updated plugin and have launched it and seen the expired message.
Return to “Patch Remedy 5”
