Build 1.0.5.8 released
We made a few adjustments to the data refreshing service in 1.0.5.7 that included refreshing the client list. We have found after a few days of running that this is counter productive. It was causing the client list to refresh while users are in the middle of a selection. When refresh hits it clears the current selected Client or Agent ID thus causing any configuration in process to fail with unknown ID.
1.0.5.8 fixes this issue. You can download it here..
viewtopic.php?p=9010#p9010
dbitters
2
Re: Build 1.0.5.8 released
Post by dbitters »
Is there a way to download version 1.0.5.9?
I'm asking because I was auto upgraded to version 1.0.5.2 but the auto-upgrade won't go past that version.
Also, in the monthly mailer, the downloads list only shows the download for the old version 1.0.4.49.
When I go online to manage downloads to get the download there, it also shows the latest download as version 1.0.4.49.
I'm wondering if I have to unsubscribe and resubscribe to get a newer version. I'd rather not do that, but let me know if that is the only way to get onto the newer version.
Thanks.
We are currently redoing our site and so There maybe be some leftover construction dust for me to clean up. I'll look at you account and see what we hae.
dbitters
2
Post by dbitters »
To give you some feedback, I removed Patch Remedy from our account and then readded version 5 with the new logo.
However, when I go to manage accounts and use the download link for that line item, it still redirects to the version 4 download. I just wanted to give you a heads up on that since I still can't find a way to download a current version for a while and the auto-update doesn't work on the version I have installed.
Thanks.
just PM you the link you need.
cmarrero
2
Post by cmarrero »
Good Morning,
We are still stuck on Version 1.0.5.8
Can you please PM the current Download Link as my account is still showing the old 1.4 version.
Thanks!
done
bfalco
2
Post by bfalco »
Download does not work, goes to info page?
Can you update the link please
Bob
Bob, Can you screenshot the link area you are referring to and send us the link in a PM?
I sent the 1.0.5.9 download link to you
bfalco
2
Post by bfalco »
Still unable to download latest version, the link brings me to
https://www.plugins4automate.com/produc ... e-automate
the refresh basically makes the plugin unusable.
Return to “Patch Remedy 5”
