I followed the instructions for installing HomeBrew, but I cannot get the version or anything to show up in the plugin on the agent. When I go look at the scripts, it just has a result of “Fail”.
I looked in the forum and saw when person recommended running the below to determine if you can install apps. It looks like the path was the issue. I then ran the below and tried again with the same result.
eval "$(/opt/homebrew/bin/brew shellenv)"
Am I missing something simple here to get this working?
HomeBrew Install Help
- 4
- Capture.png (117.4 KiB) Viewed 2550 times
Re: HomeBrew Install Help
Your current user may not have permission to see Brew if you were successful in its install.
Try the following?
Try the following?
sudo brew --version
